IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6048 Views
  • 14 replies
I've just enabled e/mobility and now I find configuring speed and fast dials via user web page giving me inconsistent results. On some phones it works fine and others it only works when you login using mobility. What's going on here?Ajaz :- /
Hi,I was asked to get the call details of a certain user then do it thru sql query on our pubs. I did get what I want...but the problem is, the date/time is not correct.i found some formula conversion:*convert from date/time:=(A2-DATE(1970,1,1))*8640...
redrobish by Level 1
  • 559 Views
  • 6 replies
I have a T1 CAS (nowhere close to a PRI)It has 24 channels used for Voice / FAX / General VM. When calls are made outside, calls go out of the available channel and displays the number of the channel. e.g. I dial a phone, the next available line was ...
joel by Level 1
  • 990 Views
  • 3 replies
The connection between CCM & CUPS is working. The troubleshoouting tool from the CUPs did not show any failure.But i cant see the status from the telephone on the presence client. I can only see the status if the user i logged on or the user has not ...
