IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5880 Views
  • 14 replies
Hello,I'm looking for the options that available today for supporting a blind switchboard operators in a CM environment.Today the blind switchboard operators have a legacy PBX phone that have the ability to fully support blind switchboard operators ...
talzohar by Level 1
  • 700 Views
  • 1 replies
Is it a must to configure the switchport as trunk while using voicevlan? if so why? My question is pc is plugged in through the back of a phone is it a must to configure that port as a trunk port int fa0/1 switchport voice vlan 100 swithport mode tru...
Hello, I am new in cisco CME. The current topology is relatively easy 12 FXO lines terminated on Cisco 2851 with CME installed. The operator has 79760 + 7914. My question is what is the best way to configure the operator lines?Is it hunt group? and...
m-haddad by Level 5
  • 628 Views
  • 9 replies
Hello,According to the CCME compatibility matrix, I need 3.4.0.1 since the ios on my 2821 is 12.4(6). I've downloaded and installed this tar on my router, but when I http to the gui and click help/about, it says that I'm using version 3.4.0.0??Is thi...
bkimble by Level 1
  • 400 Views
  • 2 replies
Hi AllTrying desperately to get IP Communicator and VT Advantage to work on new CME 4.0 system.VT works fine when associated with hardphone but IPC does not show Video icon. Video is enabled in ephone config and type is set to CIPC. I've reinstalled ...
Dear all,The CME router has VIC-2DID card which connect to CO. CO will provide 3 digit to the router. How can I configure the voice port and dial-peer for the DID function.Is the below command enough?voice-port 1/0/0 signal did immediatedial-peer voi...
