IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5566 Views
  • 14 replies
For an inter cluster non gatekeeper controlled trunk to work between two separate call managers, do the call managers have to be on the same version software release?  We have one cluster on 8.5.1 and the other cluster on version 10. I looked around ...
Has anyone ever run into this issue before? I have a cisco model 8845 video phone that on a secondary line appearance which is set for flash only it continues to ring? We are using 9.1 software on our call manager. Any suggestions as to what to try? ...
Hello, trying to plan an upgrade where I am on ESXi4.x and CM 8.6 and need to get to ESXi 5.x and CUCM 10.5.  Do I upgrade ESXi first or CUCM?.  Getting a bit confused with all the matrix reading Thanks, Replies rated.
Hi we have a new Cisco VOIP BE6000 system and we have a business hours voicemail and an after hours one.  When its a public holiday, our IT provider said to go into the scheduling part of the system (system handler? forgive me, I completely untechy) ...
CherryRHW by Level 1
  • 281 Views
  • 4 replies
Resolved! QOS set-up
Hi, wondering if anyone can help me , im trying to set-up QOS for our new VOIP phone system , but im  abit lost with the config , well really lost i am using the CCP to configure and the QOS wizard , but im unsure if i should be DSP or NBAR and also ...
paddi1972 by Level 1
  • 655 Views
  • 4 replies
