IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6151 Views
  • 14 replies
I have a 6942 given to me, but when power is applied (via POE or power adapter) all the lights flash then the "Speaker" light comes on and that's the way it stays.  I tried powering up holding the # key, but still the same symptom.  123456789*0# will...
Resolved! BE6000 CUCM setup
Hi allI was wondering if we can do the following on 2 BE6000's1 BE6000 will host a PUB and SUB, the other one a second SUB and UnityConnection. The FAQ, states max 2 nodes but further down it says the cluster can hold more then 3..... Thanks in advan...
kpintens by Level 1
  • 503 Views
  • 6 replies
Hi Guys,We have  setup a LPCOR on CME 9.1. And initial testing went successfully passed. Below is the work flows.1. user press "9" to obtain the PSTN line and input the number that they want to reach.2. CME prompt for user-code.3. user input user-cod...
Hello Everybody I have this call flow: PSTN (FXO) --> TCL File | Gw (H323) --> CUCM --> IP Phone I have next Dial-peer in Gateway whith .T pattern:dial-peer voice 101 voip translation-profile outgoing test destination-pattern .T session target ipv4:1...
