IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5910 Views
  • 14 replies
I was wondering what folks prefer as far as equipment goes when connecting a not-tiny amount of analog devices to a Cisco IP environment.  We currently have about a dozen ATA186's spread across 3 server rooms, and while I understand the pain it'd tak...
Is it possible to generate a message similar to "you have reached a non-working number" from within CUCM? We have a DN with corresponding DID and need CUCM to generate this message. I have tested and in a pinch we can just utilize the Telco-generated...
Cisco Unified CM ver8If a user doesn’t have a voicemail box and forwards unanswered/busy calls to another extension the call returns to the original extension if unanswered/busy but there is no voicemail box.How can I make the call terminate at the s...
hlewin by Level 1
  • 534 Views
  • 3 replies
Hi all,I'm new to the IT and Cisco phones environments so fairly unfamiliar.  I'm making this to see if a clients request is possible after looking around for a few hours with no clue if the search is in vain.We have Cisco  IP Phones 7945s.  We use C...
We've been having intermittent MeetMe issues since we installed our system a year ago. We are using Call Manager 8.5 with the software MeetMe bridges. Max participants is set at 50. We only have 150 ppl in our entire company and the most concurrent m...
