IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5591 Views
  • 14 replies
Hi All,We have 3 CUCM clusters. We use five digits for intercluster calls but for now we are using num-exp to send calls to the PSTN network. When I call from EU cluster to North America Cluster some strange digits get added to the extension which I ...
HI All , we have callmanger 5.1.3 integated with Active Directory 2008 , the problem is i am unable to import all user from AD , LDAP is synching properly but i can not import more then 312 user , what could be the issue ? is there any compatibilty i...
So here is another interesting issue. I have a server group that I only use for testing. Currently I can login to the publisher's OS admin page just fine, but I can't login to the subscriber's OS admin page using the same account. I can login to the ...
I have a CUCM 8.x cluster ,which was initially had a 5 digit dial plan for internal and 10 digit for external . I have converted the dial plan to e.164 global pattern . For the internal users I have created a translation pattern to convert the 5 to 1...
