IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6092 Views
  • 14 replies
Resolved! BAT Error No.
I know it's a strange title but to be honest I'm getting a strange very vague error message. This is happening when trying to create a new Phone Template Configuration for either a 7941 or 7942 phone. I've tried with various settings from just the ba...
hi friends,i am having 2851 ccme and i am having 7 analog lines and one 30 channel PRI linewhat i need is once the analog lines are used (full ) then automatically system has to select pri line to call outsideand i am using 9 to dial out.i attaching ...
zeuscyril by Level 4
  • 313 Views
  • 2 replies
Hello All,I have configured a SIP trunk to a third party PBX, and it works using G711 always with MTPs.I have tried to use G729 placing the SIP trunk in another region, but the call fails.I think that the problem is that the MTPs (I have CCM MTPs, IO...
mcecilia by Level 1
  • 377 Views
  • 2 replies
I am running CUCM 7.13b using DID's.  When I set my phone to call forward all to an external number, the caller ID does not show my DID number only the billing number for our PRI.Each line in the system is set with an External Phone Number Mask of ei...
Hi,i have a question about vocal system messages in CUCM 7.1.3. I know that, under "Route Patterns" i can select "block this pattern" and choose the voice message that gives the reason of blocking...but my need is another: can i select system message...
Is there any way I can setup an Cisco 7962 or anyother phone as a TFTP server? I know there are some IP Phones which can act as a TFTP server. Is there anyone who has done this in past or can anyone point me to cisco documentation which shows me how ...
