IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6049 Views
  • 14 replies
Hi All,I have two H323 gateways:- One for all national + international destinations- One for mobile destination.For the second one, i can just make 5 calls simultaneously and i need if there are more calls to configure auto forward to the first gatew...
Ayad by Level 1
  • 218 Views
  • 1 replies
Resolved! Conferencing issue
We have CCM 4.1(3) in Greece, it dials out via an H323 gateway which is enabled on a 2811 series router, IOS version - 12.3(11)T2.Problem - Internal conferencing works fine, but international conferencing doesn't. Suppose someone outside the cluster ...
UCBNOCWAN by Level 1
  • 9089 Views
  • 19 replies
I will be doing an IPT conversion that uses a Viking ZPI-4 paging interface. I'll be using an fxs port on the gateway for paging. The Viking manual is cryptic and there really isn't too many dip switches on it. I just wanted to see if someone could p...
mmertens by Level 1
  • 667 Views
  • 3 replies
I have added a 7970 phone but I am not getting a dialtone it is not picking up the extension either. It get the correct Ip address and CCME address. !!!!!interface Loopback0 description $FW_INSIDE$ ip address 10.1.10.1 255.255.255.252 ip virtual-reas...
