IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6177 Views
  • 14 replies
Is there any way to program a softkey for anything other then the options given? I am using one of these phones as a doorway phone and want one of the button as a speeddial that they push to ring the receptionist.
Hi,We are trying to configure a sip gateway with the below configuration. The router is installed with 4 fxo ports which i am connecting to a pstn line with the config as below.dial-peer voice 10 pots destination pattern 9tport 0/0/0forward digits al...
Hi;We have two VG224 and a 2801 router at a remote site. There is no ip phone at the site. We need solution like SRST. Anolog phones should be able to call each other and PSTN when WAN connection or CM failed. Can i achieve this goal?
Last night i upgraded to CM 5.1 from 5.0.4 and ever since then all internal calls have bad call quality. They almost sound too crisp which is causing it to crackle at times. Does anyone know how to change maybe the quality of the call or microphone l...
gmorrow by Level 1
  • 280 Views
  • 2 replies
i have a cisco voice router and legacy pbxin my site 1.I have connected 12 pstn analog lines from ISP and 20 anlog phones to this legacy PBX.Now i have to connect this PBX to my cisco voice router 2811 .I dont have E1/T1 or E&m in my Legacy PBX.i ha...
