IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6438 Views
  • 14 replies
hi all,   do you know if i use ISR4000 do the SBC < SIP Trunk > to Broadsoft    how to calculate CUBE session license?     find at Cisco website, say  "Some vendors consider one call as two sessions."    So I have some confuse.    Thank you      CUBE...
Beyondhing by Level 1
  • 5894 Views
  • 13 replies
Hello.. i have been running CUCM 10X and cisco voice gateway Router where PRI is terminated, there is MGCP b/w CUCM and router. PRI is recently termnated by provider. We have been facing frequent issue, some time when we initate call it doesnt work a...
Anukalp S by Level 1
  • 398 Views
  • 4 replies
Hello everybody, My client is subscribed to a telephony provider (analogical lines) and need to make those lines reachable through CCX call center   he already has an FXO card (4 RJ11 ports) installed in the H323 voice gateway, since i've never done ...
I need to connect a CUCM (10.5) via CUBE to a SIP Trunk. All seems to be well, but when forwarding an internal-number to a cellphone eg the carrier is expecting to see a 302 move temporarily message (when called from outside - on a trunk/trunk call) ...
