IP Telephony and Phones
Labels
Hi,   Our IT team requires a CUCM test setup(this location is not connected with our CUCM cluster) where they can check the IP Phone before to send it for RMA ..   so they are with Cisco Switch ..a good configuration machine(where CUCM can install on...
Dear community  I have 2 Cisco IP phone model cp-7821 with the following configuration:   voice register dn 15number 115name phone1   voice register pool 2id mac 701F.534C.FD0Atype 7821number 1 dn 15   --------------------------------------- voice re...
TeleCare by Level 1
  • 7273 Views
  • 2 replies
Scope:Get a spa 962 to retrieve a config file from a server using tftp or http, and properly take up the settings.Users have reportedly done it, but the documentation from cisco has nothing whatsoever.Anyway,The xml config for the phone can be reache...
uhudson_z by Level 1
  • 1252 Views
  • 2 replies
Hello, I would appreciate some sort of suggestion for this inquiry----currently, we are using sort of a   'FLOOR MATS' for the handicap clients who needs to make a call to Switch board. They come on the top of a floor mat (using wheelchair)  and pres...
GWaldbin by Level 1
  • 7896 Views
  • 13 replies
Hi all, I am searching for a way to have the communication between VOIP-Gateway (ISR4000) and IP-Phone, between VOIP-Gateway and CUCM in the global-Routing-table, and the communication between VOIP-Gateway and SIP-provider in a VRF for security-reaso...
