IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6166 Views
  • 14 replies
Hi,I have extn numbers 000-098 assigned to internal users. Requirement was: If anyone presses 0 in the IP phone it should ring the reception number is which is 099. I created num-exp 0 099-it is working. The only problem is: after this command i am u...
I'm trying to login to Extension Mobility on a 7937. When I select the service, I immediately get back a "Login unsuccessful. Login is unavailable (207)"Google shows that a 207 indicates that the device name is not being sent as part of the login req...
Hello,we are currently evaluating to replace our asterisk server with a new nice and shiny UC560.Due to very high security demands in our network we actually have two physically separated networks. One only for our work, which is NOT connected to the...
We just started having a major issues with CAD at one of our offices. Over the day all the phones will go "out of service" at random times with random amounts of time in between outages for anywhere from 3 to 15 minutes before they can go "ready" aga...
dracallis by Level 1
  • 528 Views
  • 1 replies
Resolved! Busy Tone
We are having a trouble with all phones "CISCO IP PHONE 7911" when the users try to dial to Provider Services "156" they are getting the busy tone when digit "1".Is there a configuration on call manager or on the phone we are missing?
leozin8585 by Level 1
  • 5095 Views
  • 15 replies
Resolved! DSP Farm profiles
Hi,I need to have the following services provided for a centralised, multisite cucm 6 topology.1. Callers at each site need to set up adhoc conferencing with participants located in other remote/local sites. For the most 5 persons per adhoc conferenc...
rramlal by Level 1
  • 11336 Views
  • 9 replies
Hi Guys,Is this the first experience with UCS C210 M2. I am try install the software CUCM, but, don´t work mouse, keyboard and don´t appear nothing in the video. Is there any initial procedure  to do before start work? I did found nothing error about...
I am on CUCM 8.5 and would like to get a list of DN that are used anywhere in the system.  I.e., I use the 14xx area for things like Unity VM ports and my Contact Center lines etc.  I know that I can go to Call Routing then Directory Number and it wi...
gkeel by Level 1
  • 540 Views
  • 2 replies
