IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6067 Views
  • 14 replies
Hi!Maybe someone have encountered this problem too...When secretary wants to transfer incoming call from outside to one of employees extention there is a delay about 5 sec. She uses consult transfer and when she presses "Transfer" softkey second time...
how to manipulate the outgoing number?forexample, phone registers on the router with internal number 1006, and also appears dial-peer 1006$, and calls I can make only INTERNAL! FROM 1006 to 1007 ans so on.But I cann't call PRI number, like 212345dial...
While inspecting the config of our UC520 I see it makes extensive use of BVI interfaces and bridge-groups. I see that the 802.11 radio and VLAN1 interfaces are part of a bridge-group 1 with a BVI interface setup for them and that my Voice VLAN also ...
tato386 by Level 6
  • 547 Views
  • 3 replies
Hi !I am getting the following debug output on my MGCP gateway when I want to make an inbound call. The outbound call works fine. There is 910 extension. Any ideas?thanks,KO08_2812(config-if)# *Jan 28 17:13:10.684: ISDN Se0/0/0:15 Q931: RX <- SETUP ...
Hi,I am working with 8 analogues lines for a UCME / H323 gateway (Cisco 2811). I know the Telco can configure the 8 lines in a rotary upon request but in the event that they are not. Are there any configurations on the voice ports for especially for ...
rbario by Level 1
  • 404 Views
  • 2 replies
