IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 1179 Views
  • 6 replies
Hi, folks.I've tested IPMA Assistant Console with two different clusters ( 4.1(2) and 4.1(3) ) and I had the same problem.After I launch the application the message Connection error appered in my XP station.See the part of ACLog0.txt. The Assistant u...
rdamaso by Beginner
  • 263 Views
  • 1 replies
Resolved! 2821 SIP
Got a good one here. Customer is looking at using the 2821 router. They are being delivered an ethernet pipe from a co-location facility. It is carrying SIP G.729 traffic. They want to take this traffic and convert to T1 TDM for a server locally....
dtabor by Beginner
  • 843 Views
  • 5 replies
Dear fellows, does anybody tried to register an 7906 with SRST??? in the release notice they said that is supported, but it is not true, i tested with srst3.3, and 4.0, does anybody can help me?I have a 4.2(3)CALLMANAGER and srst is in a 2851 with 12...
Now I need enable DSP resource service for hardware MTP. But I meet some trouble when I input following recommand:dspfarm profile 30 mtpcodec g711ulawassociate application SCCPmaximum sessions hardware 0 Why is the maximum session number here 0?I ca...
king-1195 by Beginner
  • 315 Views
  • 1 replies
HiCould anyone clarify the operation of dial peers.1. If you configure a single dial-peer with a called-number match and a destination pattern, will this dial peer be used for matching both inbound calls and also then sending the call out to the dest...
Strange problem:All calls that come into this location are setup to ring the receptionist phone (Cisco 7960). If no one answers this phone, the ephone-dn is set up to forward the call to another phone. The receptionist phone will also ring during thi...
HiI was reading Cisco book on dial peers and wanted to understand the logic of inbound dial peers.1. Why would you match on inbound dial peer, would it be for say a call centre to match on who is dialing. What would you do on the inbound dial peer wh...
Hi, we have a VIC2-2BRI-NT/TE and the layer 1 is deactivated. The ISDN line is a point-to-multipoint , and the carrier has test the line and all is correct (include the cable that arrive to the card). The IOS is 12.4.(4)XC4 (before upgrade we use IOS...
davidsr by Beginner
  • 1902 Views
  • 1 replies
