IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5956 Views
  • 14 replies
Hi Guys, I have outgoing Voip dialpeer where i cannot remove prefix. But we can make translation rule to omit prefix like 9 and then add outbound DID for outgoing calls. Any idea/suggestion?   dial-peer voice 2 voip description OUTGOING CALLS transla...
techguy by Level 4
  • 2539 Views
  • 7 replies
  • 5 Helpful votes
Last night we attempted to migrate from a Verizon PRI to a Comcast PRI.   Connecting to a 3925.   Both services are identical from a configuration point of view. Both are NI2 Both are ESF Both are B8ZS Both are hdlc encap Both have D Channel on the 2...
tamko by Level 1
  • 518 Views
  • 4 replies
Hi All,   I'm currently working on a CUCM 11.x cluster that has a publisher and 3 call processing/TFTP subscriber servers. I've noticed that the publisher is running on a host using a 2.2Ghz CPU with an OVA configuration that supports 1,000 users (2v...
de1denta by Level 3
  • 613 Views
  • 2 replies
I am testing this setup in the lab and if it is successful I will deploy this in production. It looks like that the CUBE function is fine however not so much for the DSP configuration.    First of all, is this setup supported? I know that that if CUB...
We need to activate LSC for all Phones to do Authorization with 802.1X (ISE).We do not need it for other function only for 802.1X1. When we activate the CAPF service and install LSC on every Phone, can we get in trouble with other function(Device Sec...
Sascha K. by Level 1
  • 288 Views
  • 1 replies
Hi there, long time reader, first time poster for the Cisco community, and i'll admit my knowledge of voice is very limited, but i have come across a peculiar problem and am hoping for an easy answer. I've looked across the forums, but can't find too...
james83 by Level 1
  • 358 Views
  • 3 replies
Hi We have CUCM 11.5 and exp-c&E 8.9 on production. We have installed Digicert pulic CA certificate on Expressway. We have also registered Cisco 8800 IP phone via MRA. (Through internet) But when we try to register SX20 through MRA (Internet), we are...
