IP Telephony and Phones
Labels
Hi All,I have an ISR cube with some SIP dial-peers and I have anti toll-fraud enabled using following configuration:voice service voip ip address trusted list  ipv4 x.x.x.x 255.255.255.255  ipv4 y.y.y.y 255.255.255.255But I still keep getting stuff i...
Ruterford by Level 1
  • 664 Views
  • 2 replies
Hello All,I've been searching the forums and product data sheets, release notes etc... but I can't seam to work out what is the current definative documetns I should be reading to - A setup the WLC to ensure I have the correct requirements for the 79...
We have a mid-size office environment with less than 100 usersIn the last few weeks, we have noticed a growing number of fraudulent calls to overseas countries. None of the employees indicated that they called any of the numbers. As well none of the ...
Hi Folk, I'm a new owner of a 7921g Cisco. I try to connect to WLAN. I Have a WPA+WPA2 protection protocol on the WIFI, so I chose Auto(AKP) protection protocol in the phone. The problem is that there is no username necessary or possible for connecti...
HI All,Facing on issue as describe below,CUCM version 8.6.2Cisco 3900 Series routerProblem description:Operator is dialing associates mobile number and patches(by transfer or conference) them in to conference(bridge) number  after that When user are ...
I am moving all of my lines to a SIP trunk.What I would like to do is have the phone company move a few DIDs at a time in order to isolate problems if/when they occur.I'm having some trouble figuring out how outbound calls work when doing this. I set...
nkillgore by Level 1
  • 653 Views
  • 6 replies
Hello all,I am having CME 8.6 having current IOS " c2900-universalk9-mz.SPA.151-4.M4.bin " with following licenses installed:License Info:License UDI:-------------------------------------------------Device#   PID                   SN-----------------...
I read that CSS is assigned to a phone. So my questions is:If I login to two phones, each one in a different CSS (hence different partitions list), then what numbers will I be able to reach depends on which phone I am logged into, right? Then this is...
