IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 1264 Views
  • 6 replies
Running CUCM 10.5 Looking to delete phones as we are charged for them however, would like the calls to continue going to voicemail even though phone is deleted. Thought calls would continue to flow as long as the directory number was in the system. A...
pvarenholt by Contributor
  • 279 Views
  • 3 replies
hello all, when i connect web page using ip phone 7965, the web page font have problem like this "[][]This[]is tes[]t web[]".how can i do for this problem? I don't know if it will help, but here's my configuration. ephone-template 3url-button 1 http:...
asdg by Beginner
  • 187 Views
  • 0 replies
Hi I'm new for cucm.Just got my be6k running and configure internal calls with users and phones. I can dial manually other phones but not through the coparate directory. The names are populated in the coparate directory but grayed out also it shows o...
zumriatha by Beginner
  • 233 Views
  • 1 replies
Hi there, Can someone please suggest what is the partnumber for the renewing the license "CUWL-PRO-K9", since this is EoL. Do i need to buy the replacement product itself, or do i have an option to upgrade/migrate. If so what is the partnumber Thanks...
sameeh.pp by Beginner
  • 256 Views
  • 2 replies
Hello All, I'm trying to register my Cisco cube router 3825 with the service provider. My cube is sending the register message with "expires: 0" even after receiving 200 OK. Are the below messages fine? As per the provider, the format is fine for th...
mailgunj by Beginner
  • 1936 Views
  • 11 replies
We have a hunt group for our product support. When everyone is on a call it goes to voicemail and although everything is setup correctly, they never get a voicemail. The voicemail picks up and it allows you to leave a voicemail but when they go to ch...
Hi Everyone, i want to ask about Route list registration:So my company has a h.323 gateway to avaya on one of branch office that has CUCM A sub  (let's say branch A). I've configured a route pattern, a route list, and a route group (which only have t...
