IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6067 Views
  • 14 replies
Incoming calls from a PRI are not reaching the phone. We are using MGCP.Here is a debug of the ISDN q931 debug:Aug 23 15:36:22 UTC: ISDN Se2/0:15 Q931: RX <- SETUP pd = 8  callref = 0x2933        Sending Complete        Bearer Capability i = 0x8090A3...
I need help setting 911 routes we send a mask number to callers so when they call back to that number they can't reach us, however i would like to send real DID to 911 can i do that?Thanks
     Hi All,                I have a CCME and AIM-CUE , Call flow is  PSTN----> CCME FXO-----> IVR(AA on AIM-CUE)----- --->Extention or OperatorCall complete normal if the pattern above is followed.but if a caller calls in and Disconnect the call dur...
alanhong by Level 1
  • 927 Views
  • 5 replies
Dear Support,I have a weird issue while on SRST. I have a PBX integrated with Q-Sig. The calls from the PBX works fine when the CUCM is available but in SRST the called number on the GW appears only first 5 digits where as the PBX sends 7 digits to t...
Dear Cisco users,I want to know of the next question is possible in cucm and certainly in version 4.2.Is it possible to schedule forwarding call for certain weeks?I will give an example:User  A can be called on his DN in work hours, but in the weeken...
glenn b by Level 1
  • 668 Views
  • 1 replies
I'm currently having some issues with adding a background image for a 7965 VOIP Phone in Call Manager 4.3, and I was wondering if it is even possible to have them in such an out-dated version of Call Manager? If anybody could give me step-by-step ins...
t.jiddy89 by Level 1
  • 1732 Views
  • 2 replies
Hi,We have a Cisco UCS C210 rack mount server that we will install CUCM 8.5 and CUC 8.5 as virtual machines.We have an exisiting CUCM server running version 6.1 that will later be removed from the network.I want to migrate the data from CUCM 6.1 and ...
ryabutler by Level 1
  • 1205 Views
  • 6 replies
