IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6059 Views
  • 14 replies
Hi,We have 2 remote sites that have both a connection to the datacenter where the CUCM and some media resources are located. There is no direct connection between those sites.We would like to allow the two sites to make calls between each other and a...
Hello Friends,I´m enabling T38 fallback cisco, but 2921 says invalid input.Can you help me please?Router2921(config)#voice service voipRouter2921(conf-voi-serv)#$l t38 ls-redundancy 0 hs-redundancy 0 fallback ciscofax protocol t38 ls-redundancy 0 hs-...
Hi everybody.Suppose we have a CUCM running tftp. We have 7940 phones registered with cucm.All our phones are running same firmware. During boot up, phones request config file from tftp(CUCM in our case). This configuration file contains among others...
sarahr202 by Level 5
  • 384 Views
  • 3 replies
Dear All,I am running call manager 9.1Is there a way i can track which ext is calling where and the time duration.Kindly let me know if this option is available in call manager 9.1Will be very thankful for your support.Regards,Malik.
tiger_401 by Level 1
  • 429 Views
  • 3 replies
Dear All,I am running call manager 9.1I have a question that when you want to make a call to any other internal ip phone user for example you press the first two digits of the other extension the i phones displays the extensions in the drop down list...
  • 1114 Views
  • 3 replies
Dear Experts,1) I would like to Add '0' to an 10 digit incoming call because i am getting only 9 digits from the SP on AnalogLine terminated on FXO using H323 Protocol with CUCM 8.5 this line is dedicated to the manager for both incoming and outgoing...
johntim20 by Level 1
  • 342 Views
  • 1 replies
