Hi allSpeed Dial not appear on phone 9785 and there is button in the phone like Other phones?Thanksakaff
Hi All,Have you guys imported multiple users from exchange to unity by using Bulk Import Exchange, if so please provide me the procedure to add them.I am looking for stunning answer.......
Hi All,We've router 3845 show belowCisco 3845 (revision 1.0) with 219136K/43008K bytes of memory.Processor board ID FHK1319F3BH2 Gigabit Ethernet interfaces124 Serial interfaces6 Channelized/Clear E1/PRI ports2 Voice E & M interfacesDRAM configuratio...
Is there a trick to gettign the NM-HDV-2V to be recognized by the 2821 router? My IOS Version 12.4(20)T4. When I do a "show diag" it says unknown Network Module.
Is it possible to delay the playback of a given voicemail box when transfering a caller into a voicemail box? Using Call Manager version 7.1.5.31900-3 and Unity Connection version 7.1.5ES18.31900-18. This is from user feedback when performing a blind...
I am trying to configure CUCM 8.03 to use LDAP synchronization and authentication with AD. The AD server uses LDAP over SSL, so I downloaded the appropriate cert, and went to upload it as a directory trust cert into the CUCM OS Cert mgmt.However, wh...
We have a SIP trunk from our CallManager 8.0 to our Service Provider and are having some QoS issues with jitter, call drops, etc. How to you assign QoS to a trunk that is terminated to CallManager and not to a router?
We are currently running a voice recording and with SIP trunk using the built-in bridge method. At the moment checking the SIP registration is very hard, in RTMT the device>>device search>>>open device search>>>SIP Trunk - only shows the CUCM ip addr...
We recently upgraded from 7.1(2a)SU1 to 7.1(3b) after our licensing TAC case was resolved (too many license files to load before the allotted time causing UCM service to fail completely). We also upgraded from the default firmware 8.5.2SR1 to 8.5.3 ...
HelloI have a CM 7.1.5 and some 7970 and 7945When I click a Corporate Directory and search a user it appears only the name and number.It is possible when I sync with AD by LDAP to appear the e-mail address, his manager and so on....?It would be great...
Hi,I need to recover SSH and GUI passwords for my client running Call Manager 7.x. I anyone knows about it, please point me to the documentation. Also, if anyone has done it before please advise..I appreciate you help..Thanks..
Dear NetPro gurus,My customer is using Unity Connection 8.0 with CUCM 8.0 and all customer phone has 3 digit extensions.e.g. 1XX 2XXAll of these phones at HK offices are in HK-Internal-PT.The original design is that this Unity Connection 8.0 se...
We did a upgrade to 7.1.2 and today users complained of call issues. It turns out the Visual and Audio setting in all the pick up groups was turned on ,when at 6.1.2 it was turned off- anyone else had this ?thanks
Hello,I have a room with two phones, both phones have the same number ( shared line).when a takes a call on one phone how can we on a simple way transfer the call on the other ? Call park solution is excluded because it will be too complex fo...
Hello allI am trying to backup my CDR's running 6.1 but it is failing. I have installed Solarwinds SFTP but cannot get them to talk.The server backed up originally but that particular server died and was taken out of the network. I am now trying to s...
| Subject | Author | Posted |
| 03-04-2026 06:20 AM | ||
| 03-04-2026 05:13 AM | ||
| 03-02-2026 07:40 AM | ||
| 03-02-2026 07:34 AM | ||
| 01-16-2026 03:24 AM |
