Wireless - Mobility Knowledge Base
Insider User Research program
Knowledge Base Articles
ResolutionIf you store traced packets in a log file, refer to the Packets Stored in a Log File section of Cisco Aironet 1200 Series Diagnostics and Troubleshooting.If you do not store traced packets, you can view the packets in real time on the Acces...
TCC_2 by Level 10
  • 635 Views
  • 0 comments
ResolutionMany factors prevents the successful transmission and reception of  wireless packets. With most common reason being interference and noise  carrier busy test is used to check the radio activity on 802.11 channels in the range of the device....
TCC_2 by Level 10
  • 12388 Views
  • 0 comments
  • 3 Helpful votes
ResolutionAccess Point(AP) can perform the functions of a Wireless Bridge and a AP at the same time, provided the AP is a dual band AP (1200, 1230, and 1240AG series) and supports the AP Link Role Flexibility feature. This feature allows AP's with tw...
TCC_2 by Level 10
  • 4328 Views
  • 0 comments
Core IssueWhen installing the client adapter on a machine running Linux, it does not find the airo.o module. You will get this message if the airo.o file cannot be found in the modules directory.ResolutionWhile the name of the module is actually "air...
TCC_2 by Level 10
  • 1012 Views
  • 0 comments
Core IssueWireless Control System (WCS) will not recognize Wireless Location Appliance (WLA) if the Wireless Location Appliance is configured incorrectly.ResolutionIn order to solve this issue:Verify that the location appliance is powered on (the pow...
TCC_2 by Level 10
  • 1228 Views
  • 0 comments
Core IssueYou can lose synchronization between LOC and WCS after the upgrade to version 2.0.42.0. Some LOC server services stop responding.The symptoms are seen when checking the LOC server status using one of these commands:/opt/locserver/bin/getser...
TCC_2 by Level 10
  • 827 Views
  • 0 comments
Core IssueThis error message appears when both the Extensible Authentication Protocol Transport Layer Security (EAP-TLS) machine authentication and the user authentication on the client utility are enabled, but the client utility does not start user ...
TCC_2 by Level 10
  • 2656 Views
  • 0 comments
ResolutionIn order to add the Wireless Location appliance to the WCS, use the default username and password, which is admin/admin. Refer to the Adding a Location Server to Cisco WCS section of Adding and Deleting Location Servers for more information...
TCC_2 by Level 10
  • 1198 Views
  • 0 comments
Core IssueApproximately 400 MAC address were already configured and then there was an attempt to configure more with the use of the graphical user interface (GUI).ResolutionUse the Command Line Interface (CLI) in order to configure up to 2,048 MAC ad...
TCC_2 by Level 10
  • 2103 Views
  • 0 comments
ResolutionNo, one cannot perform the firmware upgrade process using the radio interfaces. In order to perform the firmware job one need to select the device hostname or ip address to perform the job. This device can be a root or non-root device.In a ...
TCC_2 by Level 10
  • 1031 Views
  • 0 comments
Top Contributors
Featured Article
